Air Bubble???
Old Jul 29, 2004 | 05:45 PM
x-raydave's Avatar
x-raydave
Default Air Bubble???
Can anyone explain how I can get the air out of the cooling system
on my 1989? The Low Coolant light goes on and off and it's driving
me crazy. Radiator seems full and temp is OK. Thanks, in advance.
Old Jul 29, 2004 | 05:55 PM
black_89_vette's Avatar
black_89_vette
I'm interested in this as well. I tried removing the rad cap, starting the car and letting it idle and revving it a bit from under the hood and filling it like that.
DO THIS WHEN IT'S NOT HOT! heh
Old Jul 29, 2004 | 06:06 PM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
The LT1 engines have a little purge screw that is on the neck of the water pump. If the L-98 has the same try opening the purge with the engine running and you will bleed off air
Old Jul 29, 2004 | 06:33 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
There is also a purge screw near the bottom of the throttle body (toward the driver's side) on the LT1 - don't know if you have this also. Basically, I drained out a good portion of coolant, opened up the purge screws, and then poured the coolant back in. When I saw a nice stream coming from the screws, I closed them and then continued filling the system. This may not be the most "professional" approach, but it worked for me. Oh, and for the LT1 people, put some sort of barrier between the purge screws and the opti to catch any fluid! I forgot this my first time. DOH!!!
Old Jul 29, 2004 | 07:45 PM
cdnguyred88's Avatar
cdnguyred88
On my '88 I drilled 2 small holes in the thermostat. I had the same problem until I tried the holes in the new stat. Works like a charm.
Old Jul 29, 2004 | 07:47 PM
vader86's Avatar
vader86
Start the car with the cap off.
Let it warm up until the stat is fully open, then rev the car up to 2000rpm or so and have someone add coolant when it drops.
Wait until all the bubbles have stopped coming out.
Old Jul 29, 2004 | 08:00 PM
tempest's Avatar
tempest
when i do this by myself i jam a thin piece of cardboard (i use a piece from a tissue box) in the throttle stop to keep the revs up. add coolant as vader says, and put the cap back on when "full" BEFORE you lower the revs back down. on my 92 the window of time between the stat opens (~180) and the coolant reaches boiling is rather short (around 3 minutes or even less), so i have to be quick about it.
in my shop manual states to check the coolant level again after warming the engine up and cooling down three times, and adding coolant as necessary. it also advises against driving hard during this time (probably in case you have air bubbles).
Old Jul 29, 2004 | 08:10 PM
x-raydave's Avatar
x-raydave
Default I'm on it!
I'll try this tomorrow, Thanks Guys!!!
Old Jul 29, 2004 | 08:15 PM
Timmy!'s Avatar
Timmy!
So are there 2 purge screws on the LT1 or just 1? I see the purge screw that is on the neck that on my car is on the passenger side underneath the throttle body but that's the only 1 I see.
Old Jul 29, 2004 | 08:52 PM
tempest's Avatar
tempest
i think yours may only have one. the earlier LT1's have another that you can see from the driver's side on the throttle body, under the TB opening. it is hard to see if you are in a dark garage.
Old Jul 29, 2004 | 11:44 PM
Timmy!'s Avatar
Timmy!
Yeah, mine doesn't appear to have 2 but it looks like the casting might have previously had something there.
Old Jul 29, 2004 | 11:59 PM
comp's Avatar
comp
i drill a small hole in almost all thermostats
Old Jul 30, 2004 | 12:09 AM
tempest's Avatar
tempest
i'm wondering if drilling holes in the 'stat purges the air from the cooling system.
i CAN believe drilling small holes will make it behave like a lower temp stat by constantly leaking some coolant to the radiator.
am i missing something here?
Old Jul 30, 2004 | 12:13 AM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
No, you're not missing anything. They're unrelated.
The easiest way to solve the low coolant light problem is to fill the expansion tank. The system will take care of the rest.
Old Jul 30, 2004 | 08:35 AM
rws.1's Avatar
rws.1
There should also be an air sensor located on the engine compartment side of the rad, below the fill cap. It is the unit that senses air and sends the low coolant level code. If you have satisfied yourself that you do not have air in the system and the coolant level is above this sensor, then replace the sensor.
After this sensor is exposes to air, it will take a while to clear itself. Usually a drive of 3-5 miles is long enough.
Old Jul 30, 2004 | 06:23 PM
skidmark's Avatar
skidmark
I had the same problem with my 89 after new water pump even though I "burped" the system. For 3 straight nights I drove car, let it cool down and added a couple of ounces of AF. After the 3rd night no more low coolant light.It might help if you raise the front of the car although I didn't have to.
Old Jul 30, 2004 | 06:40 PM
tempest's Avatar
tempest
seems like your experience supports the shop manual procedure to drive it a couple of times and top the system off.
To Air Bubble???
