Does anybody know what the resistance readings should be on these injectors? I'd like to verify with mine!
These SLP injectors are take out units for LS1 engines. And they are the new Bosch 2 style injectors. These are high impedance injectors rated at 12 to 16 ohms.
and will they fit L98 TPI 87.. i thought they were 1/4" shorter and did not fit ... correct me ?
We tried them in my brothers 88 and had a hard time getting it to run right. But then again we took them out and had problems and it ended up being the ecm. Somebody tell me if they work I think i need some in my car
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
[QUOTE=Wheelman]We tried them in my brothers 88 and had a hard time getting it to run right. But then again we took them out and had problems and it ended up being the ecm. Somebody tell me if they work I think i need some in my car[/QUOTE
Did they fit ok in the `88? I bought a set, & i`m getting answers both pro & con. Did the keepers fit ok? the reason i`m replacing mine is that when I changed my plugs, every one of them was soaked with gas on the threads, & the only reason for that I could think of, would be leaking injectors. (all eight at once ?). I`m also wondering if a defective regulator could cause this. The car runs fine.
Well they fit okay, were a little shorter but seemed to seal fine from what i could tell. Definately check the regulator, mine went out and gave me issues and the shop quoted me replacement of the injectors
