Pick up Coil
Old Aug 1, 2004 | 08:07 AM
dgoodhue's Avatar
dgoodhue
Default Pick up Coil
I tested my pickup coil with a Digital VOlt Meter. In one test per the factory manual, the resistance is supose to infinite and the 2nd test it is supose to be 500-1500 Ohms. I came up with 600K Ohm and 800 Ohms. So my inital thought is that the pickup coil need replacing. I am just wonder if anyone has test a good pickup coil and found 600K ohms is close enough to infinite.
Old Aug 1, 2004 | 08:24 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I'm no expert, but I would say there is an internal short or something.
Infinite should be 0. Anything other than 0 would indicate that there is some shorting.
Old Aug 1, 2004 | 09:11 AM
NoWorries's Avatar
NoWorries
600K is a lot of ohms, I'd call that close enough to infinite for normal parameters.
What's wrong with the car?
Old Aug 1, 2004 | 12:28 PM
89C4's Avatar
89C4
No, 600k is nowhere near "infinity". Infinity in ohms is almost the same as an open circuit; mucho/max resistance. On my DVOM, infinity reads like "0.F" with the megaohm symbol in the right corner. This means that the meter cannot read what it's connected to; in other words, max. resistance in the order of several tens or hundreds of megaohms. 600K is only .6 megaohms.
Reading a short or minimum resistance shows up as "000.0" with the ohms symbol in the right corner.
Old Aug 1, 2004 | 03:16 PM
dgoodhue's Avatar
dgoodhue
The car is really hard to start when cold, the ECM isn't pulsing the injector for the first few seconds.
To Pick up Coil
