Crappy Idle fixed
Old Aug 2, 2004 | 02:12 PM
mikey whipreck's Avatar
mikey whipreck
Default Crappy Idle fixed
My 85, had a very rough idle, almost sounded like it was gonna stall once in a while. So i started replacing/cleaning stuff- one at a time so i'd be able to figure out what the culprit was. Anyway, after i changed the fuel filter; the idle is very smooth. My vette has never sounded this good at idle. Even the fuel pump sounds like its under alot less stress when it engages when you first turn the key to on. Makes me think my old one was half clogged. So if anyone out there has a bad idle- The fuel filter is a very cheap fix, and might be your problem
Old Aug 2, 2004 | 02:22 PM
Wayne88's Avatar
Wayne88
For 14 bucks and an hour of my time, I change it about every 5K miles.
Old Aug 2, 2004 | 02:31 PM
CFI-EFI's Avatar
CFI-EFI
It IS under less stress. A restricted filter puts the fuel pump under additional load that will shorten it's life.
RACE ON!!!
Old Aug 2, 2004 | 02:37 PM
comp's Avatar
comp
watch for pump
Old Aug 2, 2004 | 02:42 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
...Anyway, after i changed the fuel filter; the idle is very smooth. My vette has never sounded this good at idle...
How many miles on the odometer at the time? Thanks...
Old Aug 2, 2004 | 04:05 PM
mikey whipreck
It has about 73,600. But after pulling the old filter off, i am pretty sure it's never been changed.
Old Aug 2, 2004 | 04:55 PM
CFI-EFI's Avatar
CFI-EFI
Just for the record, another "pump killer" is running the tank low. A couple of times won't hurt anything, but as a habit, it will take it's toll. I HATE to stop for gas. Consequently, I pack that ***** as full of gas as possible whenever I stop, and let it run as dry as I dare before I stop. That has caused me to buy more than my fair share of fuel pumps. The gasoline is a coolant to the pump. Running habitually or constantly with a very low tank, will measurably shorten the life of the fuel pump. A word to the wise.
RACE ON!!!
Old Aug 2, 2004 | 04:57 PM
tobijohn's Avatar
tobijohn
Bench Racer
It has about 73,600...
Yikes! I'm only about 300 miles behind you. Mine idles fine but maybe I ought to crawl under there anyways and do the same...
Old Aug 2, 2004 | 05:01 PM
CFI-EFI's Avatar
CFI-EFI
Usually, as the filter plugs up, the system won't be able to meet the high speed demands. It is unusual for the idle to be the tip off that the filter needs servicing. The same is true of a failing pump.
RACE ON!!!
To Crappy Idle fixed
