Injector guestion
Old Aug 2, 2004 | 03:10 PM
PUREC4's Avatar
PUREC4
Default Injector guestion
Is there any way to check the flow lbs of the injector by inspection, and what is the best way the check the size of the TB. Since the guy that owned car can't seem to remember anything and the few things he has told me most of which is wrong.... when I get an answer
Thanks guys/gals, I'm starting from scratch. Still trying to load the TunerPro RT, driver problems. Hope that will give me some direction.
Old Aug 2, 2004 | 04:49 PM
ZylaRace's Avatar
ZylaRace
Size of the TB,.... yeah, measure it w/ a tape measure, dial caliper,....
Checking the flow rate,... yes you can, but it will be cheaper to send them off to one of the "cleaners". They have the electronics & graduated cyl to measure/check flow. (i.e. You gonna build a setup yourself?)
