Intermittent code 43
Old Aug 3, 2004 | 04:52 PM
STEVEN13's Avatar
STEVEN13
Default Intermittent code 43
Hi,
Car:1992 LT1
I get a code 43 (knock sensor) when I start it up. Then it goes out and sometimes goes on as I drive. What is strange is that even with it on it seems to run fine even at WOT. I checked the circuit as per my Chevy shop manual and everthing checks out.
I am thinking about getting the Ease software to monitor it, however I don't know if that would help.
Could something else give a false code?
Any help would be greatly appreciated.
Thanks,
Steven
Old Aug 4, 2004 | 08:37 AM
Unriced's Avatar
Unriced
My TPS was way out of whack and threw a code 43.. I have an L98.. I readjusted and cleared the codes. No probs now. Have you made any changes lately? Or did this happen out of the blue? Let us know
Old Aug 5, 2004 | 07:51 PM
STEVEN13's Avatar
STEVEN13
Unriced,
Thanks for the advice. This problem first happened at the track (road racing). At that time I also broke my damper, and power steering line o-ring. At first I thought that maybe the code 43 was false due to the wobble in the broken damper or maybe the powersteering fluid that leaked all over the opti.
I now pulled all the plugs and it looks like 4 (all on the same bank) have the look of a compression leak. The plugs were all tight and are bosch. I wonder if the plugs are cracked internally and they leaked? Is that possible?
My next thing I am going to try is a new set of plugs.
Thanks,
Steven
To Intermittent code 43
