rack and pinion questions
Anyone have any tips on how to do this?
2. poly mounts.
Anyone have any tips on how to install these things?
it does not seem as easy as I thought it would be.
While I have installed a new rack, I have never changed only the bushings. It MAY be necessary to R&R the rack to change the bushings. Go with your service manual, on THAT.
RACE ON!!!
Best to pull out the fan and front sway bar to get some elbow room in there. The bushing presses out with a vise and socket. Install is even easier. Positioning the rack to go in can be touchy. Get a good straight alignment and she'll drop right in.
-JRC-
RACE ON!!!
Also, I used the word "bushing", where I meant to say "mount".
RACE ON!!!
RACE ON!!!
I have had the rack out for a year and I am running a normal ratio one now.
While I could adjust the rod ends, and I do believe I looked into that, I think I was worried about the amount of threads left on the one side that would have me backing the rod end off of.
I am also running heim joints on my rack, so they are a little different then the stock tie rod ends.
RACE ON!!!
Usually an alignment can correct that but the rebuilt rack should be centered properly but many times are not.
I think someone on the forum a WHILE back said this happened to them and they had to realign the center gear or part,I forget the name to put it back in the correct spot.
Dont know if this helps.Just double check everything.
I didnt replace the bushings since it had new ones on there so cant help you much more with that.
RACE ON!!!
I will try to be more clear with my words.
I know the ratios are not going to be set up any differently, and they dont matter.
I am stating that I have 2 racks, and my standard ratio rack is working fine, my fast ratio is indexed wrong.
All i want to do is index my fast ratio one so that it is not so far out of adjustment.
For me to make my fast ratio rack go straight, and have even amount of turns on the tie rods, my steering wheel will be turned about 80-90 degrees when going straight down the road.
To simply set the steering wheel straight, and adjust the tie rods to get the front tires to go straight, this means one of my tie rods will be about falling off the threads because the rack is so far out of adjustment.
I dont want to rip the whole rack apart. All i want to do is set the rack ends evenly, pull the coupler out of the rack where the intermediate shaft mounts into it and set it back to index, so that my steering wheel would be straight, as well as my front tires.
I feel using my standard ratio rack as a guide would make this easy.
I just dont know If I can go in there and pull this steering shaft out of the rack, without causing damage, or ruining parts that are not available, or possibly never getting it back in.
I tried sending it back, but I sat in it a year before I installed it, so they could not take it back in exchange. I figured fair enough.
They did offer to look at it and have someone fix it, but that means shipping it and paying for the repairs. I figure it is about half the cost of the rack and pinion, I rather just buy a new one.
I set the tie rods even on rack.
Installed rack and hooked up tie rod ends.
Adjusted toe in by moving tie rods evenly.
Took it for a drive and pulled straight into my driveway.
Pulled the steering wheel and centered it.
Then I fine tuned my toe in and rechecked my steering wheel alignment.
All is good
All is good
