what is this sensor?
Old Aug 4, 2004 | 08:44 PM
Corvellium88's Avatar
Corvellium88
Default what is this sensor?
Hi guys,
What is the sensors just beside the coolant temperature sensor with a brown connection(like an injector connection),in front of the intake?
it's because when I disconnect this sensor,my vette runs better while a laps of time.
Thank you guys!
Old Aug 4, 2004 | 08:53 PM
CFI-EFI's Avatar
CFI-EFI
Cold start fuel injector switch.
RACE ON!!!
Old Aug 4, 2004 | 09:13 PM
Corvellium88
Thank you very much cfi-efi, do you think it could be my problem?
Old Aug 4, 2004 | 09:42 PM
CFI-EFI's Avatar
CFI-EFI
No. Not unless the SWITCH is stuck in the "on" position and constanly running your ninth injector, making it PIG rich. The TPI guys may have more to say on the subject, though.
RACE ON!!!
Old Aug 4, 2004 | 10:14 PM
Corvellium88
CFI-EFI, I disconnect the 9 injector connection and the car have the same problem,is this proof that my cold start switch is not stick open?
Old Aug 5, 2004 | 02:07 PM
CFI-EFI's Avatar
CFI-EFI
With limited TPI experience, I would say yes. With the switch disconnected, it can't feed a signal that would activate the injector. That doesn't mean that the 9th injector isn't leaking.
RACE ON!!!
To what is this sensor?
