Code 34 on L-98
Old Aug 4, 2004 | 09:51 PM
Chris9's Avatar
Chris9
Default Code 34 on L-98
I have a 1987/L-98 with a code 34 (MAF Low-voltage). I have replaced the MAF and power relay with no luck in clearing the Code 34. Any suggestions?
Old Aug 4, 2004 | 10:04 PM
vader86's Avatar
vader86
Did you replace both the relays on the firewall?
Old Aug 4, 2004 | 10:22 PM
Chris9's Avatar
Chris9
Just the power relay, not the burn off relay
Old Aug 4, 2004 | 10:50 PM
chucks88's Avatar
chucks88
Default Clear codes
Have you cleared that codes to see if the 34 came back? If not give it a try. Every so often after I've been fiddlin' with stuff under the hood, code 33 and/or 34 appear. I clear them and all is well.
Old Aug 5, 2004 | 06:54 AM
rons85's Avatar
rons85
Instead of throwing parts at it in the Hope that you finally find the "bad" one - get a copy of the Helms manual and troubleshoot it first!
Old Aug 5, 2004 | 07:04 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Code 34 is as most have said, very very often the relays
BUT, if you read the Helms manual, it can also be caused by the ECM receiving or in this case not receiving a signal that any air is flowing through the MAF.
Just one second of "no air flow" at start up will trigger code 34 and, as I have experienced, just make the car run generally crappy including loss of power at all speeds.
I found that the "no air" signal is a result, in my case, of a bad IAC. Yes, the car did and does start, but the IAC being fully closed for 1 second, the first second of cranking, established the code.
I am not sure why, but once the code is established, you are driving in "limp home" mode
I found my IAC was pretty carboned up and way out of parameters, actually fully closed at initial start up. I "adjusted it" to the 1 1/8 factory setting but since this was the second time this has happened in the last few years, I just went ahead and replaced it with a new ECHLIN IAC from NAPA
Car runs as good as new, power has returned
Don't know if this will help or not
To Code 34 on L-98
