CAT removal question
Old Aug 5, 2004 | 08:15 AM
87 rag's Avatar
87 rag
Default CAT removal question
If I remove the Cat from my 87 (replace it with a straight pipe) what do I do with the air tupe that runs into it?
Or, if I gut the cat and reinstall it hollow will this effect the same air tube's function.....What does it do?
Thank you
Also, how do I get this damn cat off? I have it undone and I've been under the car forever pulling twisting and banging. The damn thing won't slide off the front Y.
Old Aug 5, 2004 | 08:16 AM
87 rag's Avatar
87 rag
One more question.
Does anyone have any tips on gutting the cat?
Thanks again.
Old Aug 5, 2004 | 09:16 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
It won't come off willingly
I cut mine off, then I could grind a cut line into the left over piece and remove it.
I got a shop to give me a piece of 3'' pipe and had them expand one end to slide over the inlet pipe.
I then cut off about 4'' of the flanged end of cat. Used the measurements I had taken earlier, and welded the flange end to the straight pipe. Slipped it on front Y and clamped it. Bolted up rear Y and I was done.
I wouldn't worry about the air tube to cat. Tie it out of the way, or completely remove it.
I had a exhaust shop cut out my pre cats and weld in straight pipe.
Old Aug 5, 2004 | 09:20 AM
scorp508's Avatar
scorp508
Cut it off with a die grinder. Cap the AIR tube with something or remove the tube altogether and cap it further up in the engine bay.
Old Aug 5, 2004 | 09:38 AM
87 rag's Avatar
87 rag
I didn't want to cut or grind it in case I needed to use it as a decoy or something later.
I suppose I could get the end fabricated after I cut it like you said agent 86.
Thanks for the tip on capping off the air line.
My car is supposed to have 3 cats but the two front ones seem to be missing. Looks like someone before me started the job that I'm going to finish.
To CAT removal question
