Engine Mod's
Old Aug 5, 2004 | 11:10 PM
mikey whipreck's Avatar
mikey whipreck
Default Engine Mod's
I know what i wanna do for my exhaust and intake. Maybe you guys could give me some ideas for engine mods... I'd like to add some pieces to the engine itself, without removing or rebuilding it. It seems adding 1.52 MM rockers is a useful mod, So i'm gonna add those in. Are they're any similar mods I can do? ... I guess I should let you guys know my goal- I wanna be able to smoke my bro's mustang . So any ideas what else to add?
Old Aug 6, 2004 | 12:25 AM
Perfusion's Avatar
Perfusion
I wish I could help! I'm just not familiar enough with the 85 motors.... Sorry! Somebody'll chime in, though, I'm sure.
Old Aug 6, 2004 | 12:36 AM
ynk1121's Avatar
ynk1121
i know you said u have ideas for the intake but i just have to say Porting the Plemun and bolting on slp runners are worth the $$. my friend had the same camaro i had and he had it done and what a difference it makes.
edit: forgot to mention he also had the Big Mouth Tpi Base Intake Manifold
Old Aug 6, 2004 | 01:03 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you have iron heads the 1.52:1 ProMagnums will add some HP.
Exhaust mods will give a real boost, especially if you do FL headers.
Also try:
-cut back spark plugs (see my site)
-under drive crank with over drive alt pulleys
-160deg F T-stat & fan switch
-SLP ram air intake
Old Aug 6, 2004 | 02:18 AM
MrArmyAnt's Avatar
MrArmyAnt
mustang? you cant smoke his mustang? let us all hang our heads in shame
Old Aug 6, 2004 | 09:46 AM
mikey whipreck
So you see the reason I need to pump up my vette alittle bit. It's embarrasing ... To be fair his is a '97 Cobra svt. I believe those are rated at 300HP/300Torque stock.
Old Aug 6, 2004 | 09:49 AM
mikey whipreck
Also try:
-SLP ram air intake
I like the 160 Tstat and fan switch idea. And whats a site where i can take a look at those ProMagnums?
Thanks for the input btw
Old Aug 6, 2004 | 12:22 PM
shotchkiss's Avatar
shotchkiss
Why not just go with 1.6 rockers since you're replacing them.
Old Aug 6, 2004 | 05:00 PM
Red Tornado's Avatar
Red Tornado
will add approx. 10-15chp. 1.52's will give just about nothing.
Old Aug 6, 2004 | 08:55 PM
mikey whipreck
I was told I might have a problem fitting in 1.6 rockers... and that 1.52's still give a pretty good gain. What is the stock size? I think it's 1.43? Does anyone have 1.6's in their L98? What kind of 'massaging' would need to be done to get em to fit?
Old Aug 7, 2004 | 04:51 AM
crkemppainen's Avatar
crkemppainen
The stockers are 1.5 ratio non-roller, self aligning, if memory serves
go with 1.6 or 1.7 ratio with new valvesprings and you'll see some pretty good power. jegs sells them for like 180 bucks....that's almost 10 bucks per horsepower.....good money on a 'vette.
Old Aug 7, 2004 | 04:56 AM
USAsOnlyWay's Avatar
USAsOnlyWay
I would go 1.6, 1.7s might boost your power band a bit too high out of the RPM band of the TPI manifold if I understand correctly.
Ohh and just a warning, this is how I started, I know am building a stroker motor that those 1.6s I intended for my 86 are now going on...
To Engine Mod's
