LT Rocker arm question
Old Aug 6, 2004 | 12:21 PM
spinedoc's Avatar
spinedoc
Default LT Rocker arm question
Has anyone ever changed cams, springs, etc. in thier LT motor and kept the non adjustable rocker arm setup?
Old Aug 6, 2004 | 12:29 PM
Strick's Avatar
Strick
Maybe I missed something here, but don't all LT1/4 motors have adjustable rocker arms? Mine did. But to answer your question, yes I have the old stamped rocker arms and push rods.
Old Aug 6, 2004 | 02:43 PM
spinedoc's Avatar
spinedoc
My LT4 has the 'zero lash', tighten type Crane rockers. You don't have to check for any lash, you just tighten them down all the way to the stud.
Old Aug 6, 2004 | 02:52 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Something has to be adjustable....it's either the rockers or the pushrods and I don't think the pushrods are.
Zero lash doesn't mean "non-adjustable"........
We may be confusing "zero lash" with hydraulic lifters (which LT-4's have) and even hydraulic lifters have a certain amount of "lash".
Larry
Old Aug 6, 2004 | 06:52 PM
spinedoc's Avatar
spinedoc
So anyway, has anyone swapped cams etc, and kept the original rocker setup.
Old Aug 6, 2004 | 07:30 PM
96GS#007's Avatar
96GS#007
Larry
LT4 rocker arms are non-adjustable as the previous poster stated. The OEM LT4 rocker arm stud is shouldered. When the lifter is on the base circle of the cam, you install the rocker arm and tighten it to 18 lb/ft. The pushrods aren't adjustable either.
FWIW, aftermarket LT4 heads (i.e. those in the HOT Cam kits, factory LT4 replacement heads, etc) are shipped with the conventional 3/8" LT1 style rocker arm studs.
Regarding the original posters question...Some have run the HOT Cam with the OEM non-adjustable rockers. Most like to be able to adjust the rockers to a desired amount of lash.
Old Aug 7, 2004 | 01:37 PM
SunCr's Avatar
SunCr
I think it's a matter semantics - all hydraulic lifters need a certain amount of preload which for most Chevy V6'S and V8's is one turn down from zero lash. When you use a torque value, which is somewhat common place in the shop manuals these days, you're accomplishing the same thing - adjusting the preload. Go to www.cranecams.com for more info.
Other than a pushrod measuring tool, I don't know of any adjustable pushrod. Pushrods are available in different lengths and you will need a different length if you use a thinner or thicker head gasket, mill the heads or the deck surface or do anything that changes rocker arm geometry - which for GM should be 90 degrees between the rocker arm and valve stem at 1/3 lift.
To LT Rocker arm question
