first time vette owner
Old Aug 6, 2004 | 03:41 PM
Don91Z07's Avatar
Don91Z07
3rd Gear
Default first time vette owner
Hey guys ,
great site!!!!!! i just bought a 91 vette. i have a couple of questions about it. Fist of all i can hear a hissing sound coming from the inside around the brake petal. An it stops when i use the brakes. Is this normal? Second question. Is it normal for it too get about 250 degrees when it is setting still. and last of all any suggestions on my first mods. Its completely stock right now. Thanks for the help
Old Aug 6, 2004 | 03:55 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
`91 Z-07s are perfect - no mods needed
Old Aug 6, 2004 | 04:06 PM
Perfusion's Avatar
Perfusion
250 sounds a little too hot for everyday running in traffic. You can combat this problem by simply turning on your A/C - it manually turns on the fans that would normally cool your engine. Check under the nose of your car in front of the radiator to see if there's any road crap (i.e., paper, plastic, leaves, etc.) that my be impeding your cooling.
As for first mods, that's a tough one. The L98 is a great motor - bags 'n bags of torque down low, but a little lacking in the HP dept. The best way to mod any car, IMO, is to come up with a gameplan first. Decide what you want from the car, what you want to do with it (daily driving, drag racing, autocross, shows, etc.), and decide what kind of $$$ you are comfortable spending on the vehicle. With these cars, the sky is really the limit in any of the above categories - it usually all comes down to money. "You gotta pay to play" is the general saying around here...
There are many different ways to mod your car, either for more horsepower/torque, better handling, better looks, better sound system, etc. Decide what you want from the car, and we can better help you!
WELCOME TO THE GROUP!!!!!!!
Old Aug 6, 2004 | 04:07 PM
dwestsr's Avatar
dwestsr
That hiss that you hear is most likely a leaking brake booster or a leaking vacuum line to the booster. I'd put my money on the booster since you hear it inside. If you do need to replace the booster , get a metal one as the plastic ones are subject to melting if you install headers.
If it is a leaking booster, when it finally fails , you will have brakes but the pedal effort will be awful.
Old Aug 6, 2004 | 05:32 PM
crawfish333's Avatar
crawfish333
CI 6-7 & 9 Veteran
Sounds like the same problem I had recently (plus the brake pedal went 'hard.") Replaced brake booster, poof, problem was solved.
Old Aug 6, 2004 | 05:33 PM
Skippy Stone's Avatar
Skippy Stone
Sounds like a booster leak. Could be the vacum hose from the intake, though - check it out.
Mods - all at once? - bits at a time? - what "kind" of performance do you want? I have done alot of different kinds of mods. Check sig for current status.
To first time vette owner
