Keyless Entry warning light
Old Aug 8, 2004 | 10:42 PM
jonkc4's Avatar
jonkc4
Default Keyless Entry warning light
The Passive Keyless Entry light just came on my Vette's data display screen. I don't have the keyless entry fob and so have never used the keyless entry system on my 1995 coupe. The warning light stays on even when the ignition is turned off. Can someone tell me why the warning light came on and how do I turn it off? Thanks, JKK
Old Aug 9, 2004 | 12:52 AM
Red Dwarf's Avatar
Red Dwarf
You may have a fault in the PKE module? You can pull the fuse for the PKE & that may put the light out. Never tried it so don't know. It's the only component on that circuit, so you shoudn't lose anything else. It's located in the I/P fuse block, No #26, PKE, 5 amp.
Old Aug 9, 2004 | 12:26 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
The PKE also uses one of the RDO fuses (not sure which one), so if the PKE does not turn it off, try one of those.
To Keyless Entry warning light
