Fixed it (I hope)
Old Aug 9, 2004 | 07:55 AM
The Hobbit's Avatar
The Hobbit
Default Fixed it (I hope)
Well l hope this may help someone out there.
I finally fixed my code 32 problem, after some great advice from you guys I put yet another temp switch in and this seems to have sorted the problem.
As for the hard start when hot, since I got rid of the 32, if I just 'tap' the gas as it starts, all is well and I have had no problems.
Tested it this weekend with a longish journey (250 miles) in hot weather (29 C) with a few bad jams etc and I stopped the car a few times and it started fine.
I am not sure what the correct procedure is for a hot restart but if I just fire it up and don't touch the gas, it stalls after about 90 seconds
As always thanks for all the help sorting this
Barry
Old Aug 9, 2004 | 09:25 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Does this mean your back in the good books with the wifey
Old Aug 9, 2004 | 10:39 AM
The Hobbit's Avatar
The Hobbit
Yep
Been told I can go on holiday now, not be locked in the garage trying to fix it !!
Old Aug 9, 2004 | 11:20 AM
BIG JIM 54's Avatar
BIG JIM 54
"The most common cause for a Code 32 is a faulty EGR switch".
Right from the book.
BIG JIM
To Fixed it (I hope)
