Who else grinds custom cams?
Old Aug 9, 2004 | 10:14 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Who else grinds custom cams?
I've checked with Comp Cams, Crane & Lunati. Nobody has anything close to the lobe I'm after. Who else makes custom hydraulic roller cams?
Old Aug 9, 2004 | 10:20 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I'm surprised Comp won't do anything, when I visited there earlier this year, I could have sworn they said they could(not would) do anything.
Maybe they don't want to do a one off because it would cost you too much?
Old Aug 9, 2004 | 10:24 AM
JAKE's Avatar
JAKE
What lobes are you looking for Nathan?
Jake
Old Aug 9, 2004 | 10:28 AM
ZylaRace's Avatar
ZylaRace
Crower,... they are pricey.
Old Aug 9, 2004 | 11:00 AM
Nathan Plemons
Oh they can do it, but it's not a lobe that they've already done, so it would cost about $1500 for them to make it. I don't care that much about it.
Old Aug 9, 2004 | 11:06 AM
Red Tornado's Avatar
Red Tornado
Nathan, you might try these:
http://www.cammotion.com/
http://www.lsmeng.com/Camshafts.html
http://go.mrgasket.com/brands.aspx?BrandID=7
Old Aug 9, 2004 | 11:09 AM
Nathan Plemons
Jake
I want two lobes
Intake 220 @ .050 with a .400 lobe lift.
Exhaust 230 @ .050 with .400 lobe lift.
The duration is no problem but the lift is an issue
Old Aug 9, 2004 | 11:19 AM
tjwong's Avatar
tjwong
Nathan here is a couple you can try:
http://www.lazercams.com/
http://bulletcams.com/
http://www.iskycams.com/
And if that fails call my friend Kenny at:
Oregon Cam Grinding
5913 NE 127th Av
Vancouver, WA 98682 - 0899
(503) 252-5505
He can makes all kinds of cams on new cores. He has thousands of lobes to choose from and if he can't do it no one can be sure to tell him I sent you!
Old Aug 12, 2004 | 02:14 AM
JAKE's Avatar
JAKE
I want two lobes
I'm surprised they didn't advise against those specs. The ramps will have to be EXTREMELY, and I mean EXTREMELY, aggressive to give .600 lift with only 220 duration @ .050. running a 1.5 rocker.
I believe you'll have a ton of valvetrain problems/breakage with lifter acceleration rates as high as those lobes would call for.
It would probably be close to impossible to set the valves down gently enough to prevent them from bouncing off the seat and slowing the lifter enough over the nose so it wouldn't launch off the lobe would be another bugga-boo.
How'd you come by those specs anyway?
Jake
Old Aug 12, 2004 | 02:37 AM
KLLRVET's Avatar
KLLRVET
Try these guys. I think they can help you out:
http://www.elgincams.com/
They made the cam for the 409 that I have, when all of the others either said "no" or wanted thousands to do it.
Old Aug 12, 2004 | 11:53 AM
CFI-EFI's Avatar
CFI-EFI
I want two lobes
Jake hit the nail on the head. The problem isn't with the duration OR the lift. Both have been done. It is with the acceleration rates and valve control. If/when they can grind those lobes and make them reliable, they'll be readily available.
RACE ON!!!
Old Aug 12, 2004 | 12:02 PM
comp's Avatar
comp
Nathen why are you needing a ground cam ???? I'm kinda in the same
area right now ????
Old Aug 12, 2004 | 12:15 PM
ericcer's Avatar
ericcer
TPIS is doing my SR cam
Old Aug 12, 2004 | 12:17 PM
Nathan Plemons
My oil leak is back with a vengence. In order to fix it properly I will have to remove the timing cover. By that point I'm 5 bolts away from a cam swap. I don't "need" a new cam but I figured this would be as good a time as any to do it.
The problem is that I don't really like any of the other "off the shelf" cams. I want to test my theory that by increasing lift and keeping the duration small will give me the 400 RWHP I want while keeping the street manners very good, IE it should still make good torque. I'd really like to see .600 lift and I want to do it with 1.5 rockers just to preserve the lifters / pushrods with the better geometry.
Old Aug 12, 2004 | 12:43 PM
comp's Avatar
comp
OH i'm wanting to install a factory GM H.roller in a 76 block and nor need to use the GM V6 lifters.... i have 2 sets of V8's
what is your idea ??? on cam profile....
Old Aug 12, 2004 | 02:28 PM
Nathan Plemons
Old Aug 12, 2004 | 03:32 PM
sothpaw2's Avatar
sothpaw2
Jake
I have a comp cam w/ 214in /224exh @050 and .566 lift w/1.6 rr's.
His .600" lift w/ 1.5's would be a little more agressive, but is the above still saying that my valvetrain doesn't work? Seems fine after 10k mi.
To Who else grinds custom cams?
Old Aug 12, 2004 | 03:39 PM
Timmy!'s Avatar
Timmy!
http://gtp-racing.com/cam.htm
(main page)
I have a cam from them and have been pretty satisfied with it.
Old Aug 12, 2004 | 03:42 PM
comp's Avatar
comp
I also have a set of 1.6 roller rockers .....I do need input on the possible .....
Old Aug 12, 2004 | 06:19 PM
KLLRVET's Avatar
KLLRVET
(main page)
Elgin grinds cams for GTP
