Reflash
Old Aug 9, 2004 | 09:38 PM
slamin1's Avatar
slamin1
Default Reflash
I have a 90 vette with speed density system if i port the intake and heads do i have to reflash chip or will it pick up on the improved airflow by itself?
Old Aug 9, 2004 | 10:52 PM
tjwong's Avatar
tjwong
It should run fine without any additional chip programming. But once you change that cam thats a completely different story. It can however be enhanced some with a new chip. But the best thing is to get it on the dyno and see what the WOT AFR reading is at throught the RPM range.
