Lug nut specs
RACE ON!!!
Now I can get 100 ft/lbs on every lug! And the rotors are staying straight now....
-JRC-
I use either 6-point a 3/4" or a 19mm socket, either one seems to fit very snugly on the hex head of the lug nut.
RACE ON!!!
RACE ON!!!
3/4" = 19.05mm
3/4" = 19.05mm
While we're at it, can anyone tell me what, "a "3/4" SAE" socket" is? How is that different than a 3/4" USS socket?
UNBELIEVABLE!!!
Had it right all along. All C4s have M12X1.5 wheel studs and take the same thread size nuts to fit properly. The hex or wrench size is immaterial to the nut holding the wheel securely. 19 MM is the common hex size for THAT nut, although 3/4" English, will work.
RACE ON!!!
Thanks.
