Tuned Port Injection
TPS voltage?
Fuel pressure? (bosch ford injectors w/ adj fuel press. reg.)
Base timing?
Any thing else that needs to be set?
Ive had it running already but the idle floats up and down after a few minutes? Why does it have to be driven to run better as im told? ( still need aligainment) is this causing some problems?
The engine is basicly stock 30 over, edelbrock alum. heads, small cam for a TPI engine, daul exhaust, no emissions.
Any help would be great, as its ready to drive except for this!!
Initially set the fuel pressure (at idle with vacuum line disconnected and plugged) to around 48psi (if using stock size 22 lb/hr injectors). Later you can tune fuel pressure to max performance at WOT. With your setup, however, you may need more fuel pressure.
If you installed the full TPI setup there is an ALDL connector under the dash to the right of the steering wheel. You can jumper pins A&B (upper right) and use the Field Test mode (described on my site) to see if the ECM is going into closed loop mode at steady throttle settings.
The fuel trim is done by the ECM using Block Learn Mode (BLM) cell values as well as an Integrator. Data from the O2 sensor feedback gets stored into each BLM cell and is updated as you drive the car at various speeds and loads. So it takes a few miles or "normal" driving for the ECM to get enough data under various driving conditions to update each BLM cell for correct fuel trim at part throttle.
At WOT the ECM selects BLM cell #15, which always has the quiescent value of 128 (no fuel trim at WOT). This is why you can vary fuel pressure for best WOT performance and still have opimum performance at part throttle conditions. Ah, the ECM is a wonderful invention.
BTW, what year TPI setup & ECM did you install?
TPS voltage?
Base timing?
Then loosen the two screws which hold the TPS to the throttle body and rotate up upward to increase the voltage or downward to decrease it.
Once you get the setting you want, tighten the screws and make sure the voltage hasn't changed; it sometimes does as you tighten the screws. If it does change, just repeat the adjustment until you get it right.
Now, with the meter still connected, slowly open the butterflies on the throttle body while watching the voltage readings. The voltage should increase as the butterflies are opened. There should not be any voltage spikes (numbers suddenly jumping higher).
At WOT, the voltage should read higher than 4.0 volts.
Base timing is 6 degrees BTDC with the EST wire (tan wire with black stripe near brake booster) DISCONNECTED. Be sure to disconnect the battery for about 30 seconds or so after setting the timing because the ECM will store an error code when it detected the engine running with the EST disconnected.
You'll need a ScanTool or Diacom, etc., to check the IAC counts. They should be around 20 at closed loop idle.
You'll also need to make sure the system is going closed loop once the engine warmed up and idling for about 5 minutes.
Hope this helps,
Jake
If your ECM setup is from a '92 it could even be for an LT1 engine (true for Vettes, not sure about F-body though). But for sure it is for the SD setup.
You need to truely ID the ECM setup so you can be sure you are providing all the necessary sensor info to it.
