Interior differences between 95 coupe/94 convertible?
Old Aug 11, 2004 | 06:13 PM
PaceThis's Avatar
PaceThis
Default Interior differences between 95 coupe/94 convertible?
Hi all,
I'm looking to trade interiors with a fellow forum member. I have a 95 Coupe with red interior, he has a 94 convertible with gray interior.
I'm curious to know what pcs would be different b/t the coupe and convertible. I would think all the carpet pcs in the front would be the same, as well as the door sills, underdash trim, console sides, and door panels. I suspect the rear carpeting may be different, but don't know if the bottom pc. would be the same or not. I also suspect the seatbelts are differnt because of their mounting locations.
It's been a while since I've had a C4 vert, so I was hoping for some input from you guys/gals. I appreciate your help.
Thanks!
Josh Meeks
Old Aug 12, 2004 | 12:59 AM
PaceThis's Avatar
PaceThis
TTT, someone has to know this...
Old Aug 12, 2004 | 01:08 AM
wildman378's Avatar
wildman378
From what you listed just the rear carpet things like that won't fit from the seats foward it should be the same. They're a lot of difference between 94 and 95 tho but pretty sure they were just improvements and the interior was 99% the same.
I think you're good to go to change out parts from the seats foward with no problems!
To Interior differences between 95 coupe/94 convertible?
