"""Installing the 3rd BRAKE LIGHT"""
Old Aug 11, 2004 | 06:26 PM
chillcat's Avatar
chillcat
Default """Installing the 3rd BRAKE LIGHT"""
I have an 85 vette and I'm trying to wire up a 3rd brake light I had installed, does anyone know which wire in the wire harness is the correct wire to tap into for power, its not easy to apply the brake and search for the power sincehow I don't have anyone to help me.....thanks guys
Old Aug 12, 2004 | 09:19 AM
comp's Avatar
comp
use a stick or board to wedge in there If you can wire it
so you also have a light on it blink whith you turn signal
iv'e seen a couple done this way and it does get your att.
Old Aug 14, 2004 | 11:32 PM
chillcat's Avatar
chillcat
Actually....I just installed Daytime running lights, I installed sequential turnsignal lights--thats where 1 light blinks then the other blinks right after the 1st while using turn signal--and now I'm installing a 3rd light and I also have a kit to hook up to that to make it blink 3-4 times in a second when the brake is hit--for safety. I don't like tailgaters--especially in the vette
Old Aug 14, 2004 | 11:54 PM
Insane1's Avatar
Insane1
Where did you get your brake light and where did you mount it? Any pics?
To """Installing the 3rd BRAKE LIGHT"""
