head lamp problem...need advice
Old Aug 11, 2004 | 08:51 PM
SmokyMcGee's Avatar
SmokyMcGee
Default head lamp problem...need advice
When I turn my head lamps on my 85 on, they rotate and the passenger side flips up all the way, but the driver side flips up 80%.....stops then flicks up 90%, but never reaching its full rotation. Anyone know what the problem is?
Old Aug 11, 2004 | 09:15 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Try rotating the headlight manual control ****; if it feels "mushy", replace the three nylon bushings in the gear box.
Old Aug 11, 2004 | 09:21 PM
Nak's Avatar
Nak
7th Gear
I don't think 85 had the three bushings. On my 86, the motor has two nylon gears inside. I had to replace the big one that was driven directly by the motor's worm gear. I would suggest opening up the motor before ordering the part, because you might only need one of the two gears.
To head lamp problem...need advice
