tach filer
Old Aug 14, 2004 | 12:37 PM
Louis J Hoppmann's Avatar
Louis J Hoppmann
Default tach filer
Need a little help with the tach on my 90. It has started acting erratic. At WOT it is past 6k. I’m looking for the tach filter. I see the white wire going down behind the LH head like the manual says the filter should be located. Well it just disappears. Does anyone know if I get under the car will I be able to see it?
Thanks Louie
Old Aug 14, 2004 | 01:54 PM
Hooked on Vettes's Avatar
Hooked on Vettes
The tach filter is tubular in shape and is held in place by one of the engine to transmission bellhousing bolts on the driverside.
