no start,no nothing
Old Aug 14, 2004 | 07:53 PM
lowace 1's Avatar
lowace 1
Default no start,no nothing
I just finished a rebuild on my 86 coupe . new heads,cam TPIS intake and runners. New fuel pump, BBK throttle body and all new sensors. today I tried to start it,when I turned on the key to start nothing ,Fuel pressure only goes to about 30lbs check engine light stays on and when I short A&B at the DLC the fan goes on.
Old Aug 14, 2004 | 10:20 PM
comp's Avatar
comp
check elec. at batt. starter etc. anything else unplugged???batt. charged
Old Aug 15, 2004 | 12:39 AM
jfb's Avatar
jfb
If you let your battery sit while you did your engine work, then you likely have a discharged battery. Lead acid batteries self discharge 1% each day even disconnected. While discharging, lead sulphate collects on the plates and lead sulphate is an insulator. A fully sulphated battery is a door stop. You can determine the state of charge on your battery by measuring the no load battery terminal voltage (hood lights are ok). 12.0 and lower, discharged. 12.9 and higher , charged. The starter solenoid and the starter motor draw a lot of current and a discharged battery cannot supply it. Charge your battery with a battery charger for 24 hours.
To no start,no nothing
