Dyno Installtion finally started!
Old Aug 15, 2004 | 01:34 PM
tjwong's Avatar
tjwong
Default Dyno Installtion finally started!
Last week a Tim (thetoy) Del and I broke ground on the dyno installation. This weekend we dug the hole so I guess I am commited now
Here is the pit that Tim and Del dug out:
And here is what came out, anyone need any pristine fill??
Old Aug 15, 2004 | 03:28 PM
LD85's Avatar
LD85
Shazaaam! Progress is good!
Old Aug 15, 2004 | 03:52 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
No turning back now, good luck!
Old Aug 15, 2004 | 06:55 PM
STL94LT1's Avatar
STL94LT1
Default Dyno
Tom, it's really good to see that you are finally able to start the dyno install. However, I'm a little disappointed that you decided not to install it in O'Fallon, Missouri.
Best of luck.
-Mike
Old Aug 15, 2004 | 08:26 PM
LT4MOY's Avatar
LT4MOY
Good luck, I hope things go smoothly...
I'm sure once installed it will be used 24/7
Old Aug 15, 2004 | 09:05 PM
h rocks's Avatar
h rocks
Good luck Tom!
(I just wish you weren't on the other side of the planet )
Old Aug 15, 2004 | 11:54 PM
tjwong's Avatar
tjwong
Thanks guys! I got a few issues with Mustang about their design of the footings on the dyno. But rather than dealing with them I am just going to fix them myself. An hour or two of welding will fix it. I just can't beleive how some engineers design things, beats the heck out of me I just figured after spending what I did, one would expect something better.
I hope to be running by the end of the first week of September. I forgot that the concrete has to cure for three weeks before I can apply any real heavy weight on it. And seeing how I am going to need a HD fork lift plus the weight of the dyne, its going to have to cure fully before I drop her into the pit. I wish you guys were all in my neck of the woods I would invite you all over to help me break it in!
Old Aug 16, 2004 | 12:06 AM
Curveit's Avatar
Curveit
Just getting started? I thought you'd be up and running by now; I remember when you were just talking about getting it. All kidding aside, good luck with the new addition. I wish I was able to be a customer too.
Old Aug 16, 2004 | 01:06 AM
chriswtx's Avatar
chriswtx
Old Aug 16, 2004 | 01:19 AM
comp's Avatar
comp
keep up the info
Old Aug 16, 2004 | 01:52 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Tom, check out the design on this one somebody post last week. http://www.josephthompson.net/austin/
Old Aug 16, 2004 | 03:13 AM
locobob's Avatar
locobob
I'll help you break it in Tom, glad to see it's finally coming together.
Old Aug 16, 2004 | 04:01 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Woo Hooo!
Old Aug 16, 2004 | 10:03 AM
tjwong's Avatar
tjwong
Damn! Is that some kind of red neck dyno or what
Old Aug 16, 2004 | 11:10 AM
ZylaRace's Avatar
ZylaRace
The RedNeckDyno,... The chain is held in place by a SINGLE bolt. Ever see a car get sling-shotted across the road??? (Please post a pic of that,...)
Old Aug 16, 2004 | 03:09 PM
383 tpi's Avatar
383 tpi
Default Red neck Dyno
I'm just a Red Neck dyno, i aint no high class rod, just a product of my raisin, i say yes ma'am and he haw, New Country Smash Hit by red necks r us, hey if you chain yer car up to a duely you might be a red neck, if the branch falls and destroys yer fenders while you r pullin yer motor , you might be a red neck
To Dyno Installtion finally started!
