Burn off relates to cleaning the MAF wire. When you turn off the engine, the ECM will activate a relay to burn any foreign matter off the MAF wire. Never heard of a "burn off module". Just a burn off relay. Maybe the 85 does it differently?
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Originally Posted by 85autoxr
what is a burn off module? how to test to see if it is bad? and where do i buy a new one? thanks erik...
with previous poster!
The MAF has two relays ( they are identical) one powers the MAF and the other does what he said after you shut off the engine! The relays are cheap and easily replaceable!
But why do you think you have a "burn off problem"?
it is 85 only and it was used prior to the later 2 relays.... it is also used on F bodies with the 305tpi I beleive. You can check it out by having the MAF sensor intake hose off and after shut down view the wire, it should glow red, you have to do this quickly, a helper shuting the engine off and you viewing it...
