Amazing Alignment Results
Anyway, I finally decided to give it a try, so off to Ace Hardware for the conduit and line.
The instructions are pretty simple to follow with the most exacting part being adjusting the jackstands so that exact equal measurements are obtained front to rear and side to side.
Well, with all the different "recommended" settings floating around out there, I decided to give the Daily Drive settings a try. Setting Toe-in at 1/32 (each wheel) made a dramatic change in steering effort. Effort became so light I couldn't believe it.
Actually, I felt a little, (just a little) uncomfortable, because just the slightest turn of the steering wheel made the car move instantly. On the Interstate (and other rather smooth roads), following roadway grooves became "noticable" but not objectionable.
Car wasn't quite twitchy but it sure responded MUCH quicker.
I just finished changing the toe settings to 1/16" in (each wheel) for a total of 1/8" total, and am about to go for another ride to see the difference.
Guys on the Roadrace board know all about this, but getting negative camber up front can be a chore. I'm thinking that in order to get negative camber (without pulling and grinding down the spacers), I'll have to sacrifice positive caster.
So basically, what I'm doing now is getting the best I can in the camber area and then playing with toe-in.
I'd be interested in any alignment settings that any of you early C4 guys have tried and liked. Subjective comments are welcome too.
EDIT: Ben Palmer was nice enough to host the file on how to do the self alignment; the link is:
http://users.bigpond.net.au/ben_p/co...lAlignment.doc
Thanks,
Jake
http://www.harborfreight.com/cpi/cta...emnumber=45742
They are real solid plate steel construction, about 30 plus pounds each.
Front: Toe O*
Camber .25* neg
Caster 5-7* pos
Rear: Toe 1/8 in toe-in
Camber .50* neg
This is the set-up I want to try...
The 1/32nd toe-in, etc., settings I used are Daily Driver settings.
I'll edit my original post and make the change.
Thanks.
Jake
Jake
What I'll try to do, now, is post it to what use to be called "Tech Tips" under the title "Self Wheel Alignment. I haven't tried posting a TT using the new Forum; hope there's still such an animal.
Jake
If anyone wants the file, email me at jakejr266@sbcglobal.net and I'll be happy to send it.
EDIT: Ben Palmer was nice enough to host the Self Wheel Alignment file. Hosting it sure saved me sending a ton of emails; had no idea this this would be so popular.
The link is:
Jake
Care handles much better than w/ the stock settings.
Pulling up and pushing down on that sucka was wearing me out, so I opted for a mechanical solution. I used my floor jack to raise the tires off the floor, then suddenly released the jack to let the car drop. PLOP!
I then verified that distances from the wheels to my fishing lines hadn't changed; then checked my last adjustment to see if it held. A couple of times the settings needed tweaking.
When the Service Manual says the car needs to be pulled up and pushed down three times to settle the suspension, GM knows what they're talking about.
Hope this helps.
Jake
Jake
