Having brake problems need help
Old Aug 18, 2004 | 12:24 PM
RM 4 TWO's Avatar
RM 4 TWO
Default Having brake problems need help
The booster in my 92 LT1 went out last week, so I replaced it. Now the brake pedal is spongy and I don’t seem to have the same pedal travel as I use to. I thought that I might have air in the system or contaminated fluid, so I the bleed the entire system twice, including the prime pipe and master cylinder. I checked the MC and all of the lines and nothings leaking. Any ideas? I’m thinking I may have gotten a defective booster?
Old Aug 18, 2004 | 12:29 PM
bogus's Avatar
bogus
spongy brakes point to a bad master cylinder. you may not have noticed it with the bad booster.
Old Aug 18, 2004 | 01:22 PM
zrracer's Avatar
zrracer
St. Jude Donor '11, '14
Make sure that nothing got in the vac line.
Robin
Old Aug 18, 2004 | 01:49 PM
RM 4 TWO's Avatar
RM 4 TWO
I guess that's possible. However, I didn't have any problems prior to the booster going bad. The inner seal on the booster split which caused a vac leak. I essentially had manual brakes for a few miles till I got it home. You would think the MC would give you some signs before it stopped working?
Did that. Replaced the check valve and grommet as well.
Any other suggestions.....
To Having brake problems need help
