92 conv. install a chip?
Old Aug 22, 2004 | 10:28 AM
dodsond's Avatar
dodsond
Default 92 conv. install a chip?
My first Vette. Just picked it up Friday. 2.59 gears. Not the performer I thought it should be. Chalk it up to long gears. But, do you all recommend a chip as my first HP upgrade? Much difference? Or would Aircleaner, exhaust, hotter ignition be a better start?
Also, I hear alot about water on the Opti-spark. When one crashes, is there an upgrade to prevent future problems with it? I REALLY want to detail under the hood of my car, but worried about the water thing....
Old Aug 22, 2004 | 04:35 PM
ANTI VENOM's Avatar
ANTI VENOM
My opinion is save your money for gears,convertor or both. Good luck!
Old Aug 22, 2004 | 06:35 PM
Fozzy_Bear's Avatar
Fozzy_Bear
Waka, Waka, Waka!
CI 4-6-8 & 10 Veteran
St. Jude Contributor
Long tube headers are one of the most often recommended mods. After that, I'd go for the gear swap, and probably upgrade the rear from a D36 (came stock in auto-tranny vettes) to a D44 (stock in the manual's). Just remember, the drivetrain is a SYSTEM, and not just a collection of parts. The choice of gears is tied closely to the Camshaft lobes and the piston size. Other than the basics (headers, cat-back, Air-Cleaner) you can start some very involved projects by making what seems to be 'just a small change". Of course, there is nothing Corvette-Specific about that.
Old Aug 24, 2004 | 10:10 AM
rws.1's Avatar
rws.1
Opinion, here is that chips don't do much on stock engines...
If you have modified your engine, then get a custom burned chip.
There are several forum members offering those services, just search this forum.
Old Aug 24, 2004 | 11:53 PM
dodsond's Avatar
dodsond
Thanks folks. I'm going to work on doing a long overdo plug/wires tune up. I hope that will yield more than the chip...Had tranny flushed, air filter, and a Mobil 1 oil change yesterday.
To 92 conv. install a chip?
