oil leak, suggestions?
Old Aug 22, 2004 | 02:53 PM
Jet-Jock's Avatar
Jet-Jock
Default oil leak, suggestions?
Noticed this morning I have an oil leak. Put the vette up on the ramps and crawled under and could not determine where it is coming from. Cleaned it up and guess I'll monitor it but looks like a trip to Chevy. Damn... not a good day today. Battery died while it was on the ramps had to go get a new battery.
I stuck the camera down there and took a bunch of picture trying to see if I can see it from the pictures but unable to. It wasn't there when I changed the oil first day of summer.
So folks, any ideas where this might be coming from?
Checked the oil level and its still right at the top mark.
Old Aug 22, 2004 | 03:03 PM
comp's Avatar
comp
need pic of other side. also drive slow around after cleaning and look
Old Aug 22, 2004 | 03:11 PM
Jet-Jock's Avatar
Jet-Jock
I took a bunch by sticking the camera down near the opti but it wasn't darn near impossible to tell anything. I just got the battery in and let it idle for about 4-5 minutes.
Stupid brace is in the way to get a good view of anything. I'll run it around the block and see what more images I can take. Most of them are just not usable. Thanks
Old Aug 22, 2004 | 03:32 PM
greenvette95's Avatar
greenvette95
St. Jude Donor '03
If it's like my 95 LT1 my leak was the intake man up front right above the opti. If you have the same problem look real close right above the opti, you will see oily dirt. That is just below the leak. You have to put a new intake gasket on. dealer is about $658.79 I know thats what it cost me. my .02, good luck
Old Aug 22, 2004 | 03:48 PM
STL94LT1's Avatar
STL94LT1
Default Timing Cover
The oil leak may be coming from one of the timing cover seals.
If it is an intake gasket leak, fix it yourself. Pulling the intake on an LT1 is easier than changing spark plug wires.
Old Aug 22, 2004 | 04:13 PM
Jet-Jock's Avatar
Jet-Jock
I just drove it around the subdivision and didn't see any new on the oil pan. But I did get a picture of the passenger side right side of the engine. I noticed a little oily like area there. But this was there before I cleaned it and I didn't clean the exhaust manifold. Is this the area your talking about?
I have to drive to south Orlando so when I get back there might be some I'll check it when I get back.
Man this is depressing.
Old Aug 22, 2004 | 04:58 PM
lefoy84's Avatar
lefoy84
See if the valve cover bolts are tight.
Old Aug 22, 2004 | 05:21 PM
86PACER's Avatar
86PACER
Definately looks like either the front of the intake, valve covers, or both. If you have the tools and the time, I would fix the leak myself and save a good ammount of money. if you have never pulled the intake before, it's not as hard as it might look.
Old Aug 22, 2004 | 05:28 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
That price is a royal reaming! This would not be over a 3-4 hour job on an LT1 even for a novice. $20 for a Fel Pro gasket and a tube of quality sealer. The LT1/ 4 intakes are nothing like the cluster-foxtrots on the L98s!
Old Aug 22, 2004 | 09:01 PM
Jet-Jock's Avatar
Jet-Jock
I just got back from an 80+ mile trip (interstate), actually first time I've got to run her in about 4-5 weeks since its been just local driving. Anyway, ran her constant at about 2000 rpm which averaged about 75-80+, I looked with a flashlight at the oil pan and I can't see any fluid on the pan. I'll get to look more closely at it tomorrow and also check the torque on the valve covers.
As I was saying before I changed the oil on the first day of summer and when I do oil changes I always wipe everything down underneath. There was no leak then, but I really haven't driven it much other than local since. From the first picture although it looked bad there was no oil on the garage floor.
I'll post an update what I find tomorrow.
Thanks guys for all your suggestions and help.
Old Aug 23, 2004 | 08:20 AM
runner140*'s Avatar
runner140*
Default Oil leak
It could be coming from a number of places. First, clean the area that is oiled, then run the car up to normal temp. When the oil is up to temp, you should be able to see where it is coming from. Give it a try.
Old Aug 23, 2004 | 10:32 AM
rws.1's Avatar
rws.1
Sometimes the problem is that the gaskets have gone hard with age and heat they don't give a complete seal when the engine is cold .
You might get some seepage under these conditions for two reasons.
1. The oil pressure may be up to 5 pounds higher ( I see that on mine all the time until it's up to operating range)
2. When the engine heats up, the metal expands slightly and may be just enough to restore the seal
The key as others have identified is to clean the engine and find the source.
Good Luck
Old Aug 23, 2004 | 03:18 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Get the Fel-pro intake gasket kit and use copper RTV sealant and you'll be good to go!
Old Aug 23, 2004 | 03:28 PM
comp's Avatar
comp
Good Luck
you may just have found something that isnt ready to be fixed
so do a complete clean and watch it.. don't sweat it ,if you cruzed that far and still ok i'd watch if mine. my 2cents
To oil leak, suggestions?
