under hood lights
Old Aug 23, 2004 | 12:01 AM
Clemson Vette's Avatar
Clemson Vette
Default under hood lights
tomorrow i'm showing my car at a club fair type thing. i need to keep the hood open all day and want to turn the lights off. i have no switch. is there a way i can just unplug them? where is this plug located at? it wont mess nothing else up will it? thanks men.
Old Aug 23, 2004 | 12:07 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Follow the pair of black wires from the hood lights down to the headlight wells. there you should find a connector (one each side) that can be unplugged. No damage will result.
FYI. I installed a small switch on each light to kill the lites when the hood is open.
-JRC-
Old Aug 23, 2004 | 12:08 AM
white90conv's Avatar
white90conv
On the '90 there is a connector on each side of car in the front part of the engine compartment (not on the hood). There is one for each light. They are near the headlight connectors.
Old Aug 23, 2004 | 12:13 AM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
If your '95 is like my '93, down in the front drivers side, down where the round plastic ball is. There is a fuse holder. remove the cap and take out the fuse.
Old Aug 23, 2004 | 12:33 AM
xs650's Avatar
xs650
-JRC-
I moved the wire from the right light so it picked up power at the left light. One switch turns them both off now.
Old Aug 23, 2004 | 12:54 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I just leave mine unplugged and made dummy plugs for the weather pack connectors to keep dirt and corrosion out. I know where they're at if I ever need them.
Old Aug 23, 2004 | 01:17 AM
jabez's Avatar
jabez
I normally just unplug the wires that lead to the connectors around the wheel well if I have to open hood long periods of time.
Old Aug 23, 2004 | 01:29 AM
mikey whipreck's Avatar
mikey whipreck
You could always just take the lightbulbs out... that'd be easiest i believe
Old Aug 23, 2004 | 01:37 AM
jabez's Avatar
jabez
unhooking the wires at the connector is a 5 second job for each light.
Old Aug 23, 2004 | 01:43 AM
lt1george's Avatar
lt1george
Default hood lights
Unplugged mine,left unplugged for years no problem. But never drove my 95 in any bad weather.Save the Wave.>George
Old Aug 23, 2004 | 09:09 AM
Ruby Fan's Avatar
Ruby Fan
I unpluged my '85 and wrapped elec/duct tape around both the open ends. I'm too much of an under the hood guy to have those lights on all the time.
Old Aug 23, 2004 | 03:20 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I just pull the underhood fuse on my '92 as explained in the Owner's Manual.
Old Aug 23, 2004 | 03:32 PM
Ruby Fan's Avatar
Ruby Fan
The early(?) C-4's don't have a separate fuse for these underhood lights. These lights are part of another lighting system. My '93 as in the other '92 at least had a separate fuse for these lights, just for guys like me . I don't what year they made the change-over.
To under hood lights
