86 auto dumping trans fluid, need help
Old Aug 22, 2004 | 04:48 PM
GarryZR1's Avatar
GarryZR1
Default 86 auto dumping trans fluid, need help
My 86 suddenly just started dumping trans fluid from the torque converter area. It still runs fine. Lots of fluid & smoke as it gets on the exh system. Does anyone know what this might be, where is best place to get fixed? The car only has 24,000 miles on it.
Old Aug 22, 2004 | 04:54 PM
lefoy84's Avatar
lefoy84
Probably the front seal. Trans must be removed to replace.
Old Aug 22, 2004 | 05:02 PM
CFI-EFI's Avatar
CFI-EFI
Check your cooler lines, too.
RACE ON!!!
Old Aug 23, 2004 | 10:48 PM
GarryZR1's Avatar
GarryZR1
Will do tomorrow. Is it a big deal to replac the seal? While I have the trans out is there anything esle I should do?
Old Aug 23, 2004 | 10:50 PM
Jloshotz's Avatar
Jloshotz
Once the trans is out, the seal is about a 5 minute job, tops
Just be sure to check the converter to make sure there are no deformities cutting into the seal or it may go again
To 86 auto dumping trans fluid, need help
