head question ?? help please
Old Aug 24, 2004 | 12:13 AM
reed62783's Avatar
reed62783
Default head question ?? help please
How much power would i gain from having my heads ported and polished?
Would i be better off buying diff heads?
also is 600 a good price for doing this (keep in mind that they will already be there changing cams) ?
will i be able to run around 13.0 with only a hot cam kit and polished heads?
92 LT1 A4
2.59 gears
Old Aug 24, 2004 | 01:17 AM
vader86's Avatar
vader86
You would be better served by doing gears and/or TC before the hotcam, but its possible to break 13.0 with just the cam kit, the head porting should net about 20-25hp but it depends on how far you go with the portwork.
Old Aug 24, 2004 | 01:27 AM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Agreed with Vader in terms of gears. Simply doing gears and NOTHING else will help tremendously. If you're going to do the Hotcam, you definitely need more cylinder head than the stock '92 heads. As far as porting and polishing the stock castings, I'm leary of the gains to be had from a $600 port job. However, price doesn't determine quality. I flowed a $1900 set of CNC heads from Tampa, and they only flowed 260 and 180, well below the advertised 280 and 200. If you start looking at spending that kind of money (i.e. $2k+), go with aftermarket heads. AFR is pretty much the only option for the LT1, but for $2500 they'll send you a set of heads WITH whatever springs and whatnot you need. So, if you are planning on changing valve springs, valves, retainers, etc with the Hotcam swap (which is good idea, hint hint), then the price starts looking for attractive. Don't forget that a stock set of LT1 heads is worth $400-500 or more on eBay, so you can recoup some of the cost. However, it's up to you how mild or wild you want to go.
Old Aug 24, 2004 | 01:34 AM
reed62783's Avatar
reed62783
so u think that the hp diff would only be like 20-25. wow i figured closer to 50.
Old Aug 24, 2004 | 09:12 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Nothing to sneeze at, that'd be a nice gain for a few hundred bucks. If you decide to go with gears, even the 3.07s would give you a decent pick up from the 2.59s and still allow great highway cruising mileage. If you don't care about that, someone here should know the best 1/4 ratio for a mildly modified LT1 automatic. You should be looking at real solid 12s easy, if you do it all and tune. Oh BTW, check what Mr Mojo has accomplished, ET-wise with NO real engine mods, just gears, converter, tires and driving!
Old Aug 24, 2004 | 09:23 PM
reed62783's Avatar
reed62783
bump!!
anybody have any idea on performance increase with heads?
or does 20-25 sound right
Old Aug 24, 2004 | 09:36 PM
vader86's Avatar
vader86
http://www.wku.edu/~nathan.plemons/h..._corvette.html
You can see what Nathan got on his, but note he already had all the other mods before headwork.
To head question ?? help please
