Master Cly replacement
Old Aug 24, 2004 | 12:01 PM
PUREC4's Avatar
PUREC4
Default Clutch Master Cly replacement help
Any special notes on changing the clutch master cyl. Nothing in tech help. Special tools required. Looks like I need really small hands to get to it. Don't even go there guys . And under the dash? Should I bench bleed the cyl befor installing it?
Old Aug 24, 2004 | 01:58 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
Nothing hard about it. Getting under the dash and contorting to get the clip off the pin is the hardest thing. Be carefull with the hydraulic line, use a line wrench if you have one. No need to bench bleed the master; but getting the air out of the slave can pose a problem..........my 95 is a snap, unlike the earlier slaves. What year is your car?
It might be a good idea (as is usually recommended) to change the slave cylinder at the same time. When I did my master I did not do the slave right away. It was less than 6 months later that I had to do it.
