MAF Relays?
Old Aug 25, 2004 | 01:56 PM
Aardwolf's Avatar
Aardwolf
Default MAF Relays?
I'm planning to order a wells MAF and want to get the relays to. Does anyone know the OEM part numbers of the relays and where they are located? Thank you!
Old Aug 25, 2004 | 02:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
On my '88 the relays are located above and behind the battery on the firewall.
You can likely get the part numbers off the tops of yours.
Old Aug 25, 2004 | 05:14 PM
Aardwolf's Avatar
Aardwolf
Great, thank you! With the threads on testing the MAF. Is it ok to drive the car with the MAF disconnected for testing purposes or should the car only be idled quickly to test? I plan to get the Helms books as soon as I can. What MAF brand do you use?
A
Old Aug 25, 2004 | 07:10 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
On my 88, the pair of relays is located in front of the battery on the inner liner around the wheel. They are mounted on a single "holder" fastened to the inner wheel well by a sheet metal screw that is accesible (philips) without removing the wheel.
On mine, till I did a little backyard engineering, you had to remove the fastener in order to get the relays off the holding frame.
My 88 is almost the last of the 88'sand I have found there are several '89 changes incorporated in it. Maybe that explains why my relays aren't on the firewall behind the battery
seeya
Old Aug 25, 2004 | 10:08 PM
stick91's Avatar
stick91
The part numbers for the relays on my '87 were 14089936 (both the same). I paid $11.92 each.
I also cleaned the thin wire with carb cleaner when I replaced the relays (very careful not to touch the electronics - just the wire). No more codes thrown.
Old Aug 25, 2004 | 10:17 PM
Curveit's Avatar
Curveit
My late '86 has two different part #...the burn-off is not the same # as the other, so there were changes through the years.
Old Aug 26, 2004 | 08:58 AM
redvette1986's Avatar
redvette1986
Mine too... Now, which is which? I think that the inboard relay is the burn-off correct?
Old Aug 26, 2004 | 09:11 AM
87SAM's Avatar
87SAM
On my 87 the burn off relay has 4 wires to it and the MAF power relay has 5 wires to it.
Old Aug 26, 2004 | 09:18 AM
TALMADGE's Avatar
TALMADGE
I have had a 33 code and replaced the relays twice. I still have from time to time the code. Where is the thin wire located that you cleaned? This may be my problem.
Old Aug 26, 2004 | 09:33 AM
redvette1986
I think he was referring to the sensor element inside the MAF itself. Remove the flexible duct in front of the throttle body, remove the maf wire connection and unclip the maf to get it out. Th wire is inside behind the screens (if you still have them on). BE VERY CAREFUL WITH THAT FINE WIRE!
Old Aug 26, 2004 | 09:40 AM
rick lambert's Avatar
rick lambert
Sorry, but I wouldn't mess with the wire in the MAF, if you do, prepare for a new MAF, there EXTREMELY sensitive. Check these three wires, the dark blue wire, the green wire or the black wire, since they can all affect the MAF-might as well check all three for clean and good connections.
Old Aug 26, 2004 | 09:46 AM
rws.1's Avatar
rws.1
My '88 is a March build. If you are still looking for relay location and part numbers, I can check tonight when I get home from work...
Old Aug 26, 2004 | 11:00 AM
JAKE's Avatar
JAKE
A couple of times a year I pull my MAF, turn it upside down and spray the sensor wires with carb cleaner.
In the past I had trouble with K&N filter oil coating the MAF sensor wires which threw off the info the ECM was receiving.
Jake
Old Aug 27, 2004 | 12:57 AM
stick91's Avatar
stick91
Couldn't have said it better myself
Old Aug 27, 2004 | 01:16 AM
stick91's Avatar
stick91
Rick:
I agree there are some risks messing with the MAF, but if you're getting a code and tried replacing relays, cleaning connections, etc without success, I think you really have nothing to lose at this point. When I bought my '87 last year, I always got a MAF code (and a terrible idle) at startup. My last resort before buying a new MAF was to remove the screens and clean the wire. I'm happy to report that after the cleaning I have not thrown any more codes and the idle's been perfect - one year and counting!
To MAF Relays?
