LT 4 Difference?
Old Aug 26, 2004 | 07:43 PM
legendzzz's Avatar
legendzzz
Default LT 4 Difference?
What exactly is the difference between a 1996 Coupe and the LT4 besides the engine?? Is it Easier to get HP out of the LT4 with less work? Please fill me in? Thanks
Old Aug 26, 2004 | 07:52 PM
xs650's Avatar
xs650
I'll start so I get to just give you some background instead of answer the difficult part
LT-4 stock has about 50 actual hp more than the LT-1. It is only rated 30 hp higher. They didn't want to embarass the LS-1 that was due to come out in 1997.
Most LT-4s were coupes. LT-4 is the engine that came with all 6-spd Corvettes in 1996 and wasn't available on the automatics.
Old Aug 26, 2004 | 08:53 PM
vader86's Avatar
vader86
The main difference between LT1 and LT4 is the heads, cam, and intake manifold.
Its easier to make more power with the LT4 because the ports are larger.
Old Aug 26, 2004 | 09:24 PM
96BLKTN's Avatar
96BLKTN
The injectors are 2 lbs more @28lbs. Timing chain is better, plug wires are red don't know if they are better??
Old Aug 26, 2004 | 11:17 PM
JA94vette's Avatar
JA94vette
I had the same question a little while ago and I found this site and it was very informative to me. http://www.grandsportregistry.com/lt1vslt4.htm
To LT 4 Difference?
