95 LT-1 wont start
Old Aug 28, 2004 | 10:39 PM
pocolena's Avatar
pocolena
8th Gear
Default 95 LT-1 wont start
So I changed plugs, fuel pump and filter..still only cranks, at the very end of the cycle it hits a couple of super weak attempts. My battery went dead so i took it out and recharged. if i ge an autoxray 2000 can it read the codes sense the battery has been disconnected
Old Aug 29, 2004 | 04:27 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Try the fusses on the pass side of the car or under the break booster
usualy the pass side fuses. Let the car set for 30 min so the system can clear computer information my 94 does this all the time just in case check the conector at the fill tank.The brown wire at the tank is the power wire but only has power for a few seconds when key turned on.
Old Aug 29, 2004 | 12:21 PM
tjwong's Avatar
tjwong
First off have you checked for the obvious, spark and fuel pressure??
To 95 LT-1 wont start
