Headlight Problem
Old Aug 31, 2004 | 08:30 AM
Texas White 93's Avatar
Texas White 93
Default Headlight Problem
My right headlight on the Corvette I just bought started to only go up half way sometimes and moves around and sometimes gos all the way up but moves around. Do I need a new headlight motor or can this one be fixed. I have not a clue. I am waiting for some repair books My first Vette. Thanks
Old Aug 31, 2004 | 11:53 AM
Steel Blue 91's Avatar
Steel Blue 91
There are some tech tips (when available) on replacing the plastic bushings in the headlight. They should help you out.
Old Aug 31, 2004 | 12:07 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Sounds like it could be your bushings. Go to Home Depot and ask for item 595609.
You will need six (6) of these nylon spacers to repair both headlights. They cost like .69 cents for a pack of three.
Then go to C-4 TechTips on this Forum and search for "headlight repair." If you have any questions, holler back!
Old Aug 31, 2004 | 01:19 PM
Texas White 93
Thanks I will go to Home Depot and get the bushings, but I can not find anything that says Tech Tips and I do not see any way to do a search. I see the Tech/Perf. As you can see I am not the sharpest knife in the drawer. Thanks in advance if you can tell me how to do this.
Old Aug 31, 2004 | 02:33 PM
onedef92's Avatar
onedef92
It looks like that section of the Forum is temporarily unavailable until Troy gets all his new hardware back on line.
In the meantime, try this link. It outlines the procedure very well.
http://www.corvetteforums.net/tech/headlight.html
Old Aug 31, 2004 | 04:33 PM
Texas White 93
Thanks, I will try to fix tomarrow. This Forum is really Great
Old Sep 1, 2004 | 05:29 AM
onedef92's Avatar
onedef92
If you run into any snags, holler back. It's a little time consuming, but not that difficult a job once you get the first one under your belt.
Old Sep 2, 2004 | 05:37 AM
SSN591 Shark's Avatar
SSN591 Shark
I used the Delrin bushings from Corvette Central in my 88... solved all the problems you are having... ... just buy the bushings now and fix it on a weekend.
http://www.corvettecentral.com/
88-96 Headlight Motor Repair Kit 444359 5.20 Kit
88-96 factory headlight motors contain a drive gear that is gel packed, and it is this packing that fails and allows the motors to free wheel. The repair kit contains 3 Delrin bushings that replace the gel and allow the motors to operate properly. Easy installation - one kit needed per motor. Instructions included.
To Headlight Problem
