Need Help:Valve Train upgrade for LT4?
Old Aug 31, 2004 | 08:35 PM
silver & red CE's Avatar
silver & red CE
Default Need Help:Valve Train upgrade for LT4?
I'm finally installing my headers. While I'm at it I'll put my Hurst line loc and Harlan shift light. Time for some sub 13 second runs!
I'm also upgrading my valve train, here's what I was thinking:
Comp Cam 26918 bee hive valve springs
Comp Cam 772 Ti valve retainers
Comp Cam 7/16 1.6 Pro Magnum rockers
guide plates
hardened pushrods
7/16 small block rocker studs
What do you think? I want to install a comp cam 305 cam this winter, is this valve train going to work?
Thanks,
Eric
Old Aug 31, 2004 | 08:48 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Since they're all Comp Cam parts, would they have a pretty good idea how it'll all work together?
Corvette Kid
Since they're all Comp Cam parts, wouldn't they have a pretty good idea how it'll all work together?
Old Aug 31, 2004 | 09:20 PM
silver & red CE
But what about 7/16" rockers, instead of the 3/8", any issues?
Eric
Old Aug 31, 2004 | 09:40 PM
Corvette Kid
Eric
They're just more durable, that's all. CC makes rockers for both sizes.
Old Aug 31, 2004 | 10:03 PM
silver & red CE
More durable? I know they flex less (if it makes a difference under 6500 rpm) how are they more durable?
Eric
Old Aug 31, 2004 | 10:21 PM
96GS#007's Avatar
96GS#007
FWIW, the beehive springs won't fit the stock LT4 valve spring seats (ID interference) and the LS1/6 seats won't fit the LT4 heads unless you've machined the valve guide bosses. I would contact CompCams about what seats to use or to find out if you can mod the LS1/6 seats.
Old Aug 31, 2004 | 10:35 PM
silver & red CE
Originally Posted by 96GS#007
FWIW, the beehive springs won't fit the stock LT4 valve spring seats (ID interference)...
Duh! (as he hit's his forehead w/hand).
Installed Load: 105 lbs @ 1.800" 130 lbs @ 1.800"
Open Load: 293 lbs @ 1.200" 318 lbs @ 1.200"
Spring Rate: 313 lbs/in 313 lbs/in
Coil Bind Height: 1.085" 1.085"
Outside Diameter: 1.290"/1.060” 1.290"/1.060”
Inside Diameter: .885"/.656” .885"/.656”
Retainer: TI 772/Steel 774 TI 772/Steel 774
Part # 26915-16 26918-16
Description GM LS1 Spring High Load Spring
The ID on the LS1 spring is 0.885", I measure the LT4 springs at 0.900", I thought it was close enough....
Old Aug 31, 2004 | 11:12 PM
96GS#007's Avatar
96GS#007
FWIW, I just went out to the garage and measured a couple extra LT4 springs and seats I have. I came up with a spring ID of .915 and a seat measurement of .910 Whatever the case, the beehive won't properly fit IMO.
If I were you, I'd talk to Comp. Failing that, I'd buy the beehives and mock one up on the LT4 seat. You'll find they don't seat all the way (close, but not quite). Over time you risk the spring cracking the spring seat and introducing metal particles into the engine.
Lastly, I'd buy an LS1 seat and see what it takes to modify it to fit over the guide. It may be as simple as enlarging the hole in teh seat via drilling on a drill press. I believe forum member "No Go" did something like this for his 381 build up.
Old Sep 1, 2004 | 02:18 AM
tjwong's Avatar
tjwong
Comp makes a set of spring cups to enable you to use the behive springs in other applications than an LSx engine. But as Jim mentioned its better to speak with Comp to get the correct spring cups to suit your needs. These cups also are .060" thick and that may come into play with the final installed height of the spring.
Old Sep 1, 2004 | 06:24 AM
LT4BUD's Avatar
LT4BUD
07-503-8 Cam
1318-16 1.6 ratio, 3/8" rocker arms
26918-16 Springs
4505-16 Hi-tech studs-7/16 base, 3/8
787-16 Spring Retainer
7940-16 5/15 7.200 pushrods
Can't remember why, but 7/16 studs wouldn't work...used high strength 3/8"..
Remember never trust compcams hot line!!!!!! Call them over and over until you get something resembling a consistent answer, different tech reps will give you varying answers, often criticizing another reps recommendation!!!!!!
BTW, my last call to CompCams was to get a Max RPM for this setup...their answer is why would I ever want to rev above 5900, since this would be above the power band of this cam....car dynos 365rwhp at 6400 rpm!!!!
IMHO don't believe anything Comp Cams has to say!!!!!!!
Old Sep 1, 2004 | 07:26 AM
silver & red CE
Anyone else have issues installing the 7/16" rockers on an LT4? I know several folks have run the 7/16" rockers on 113 L98 heads...
LT4Bud, what did you do for the cups?
Eric
Old Sep 1, 2004 | 08:31 AM
LT4POWR's Avatar
LT4POWR
Eric
I'm running 7/16" studs & rockers without any issues.
Old Sep 1, 2004 | 08:37 AM
silver & red CE
Cool!
I call CC about the cups. No kidding about the "TECH" line. I kept pushing for an answer on the spring cups, the tech rep finally went back to engineering and asked, there's a new part number for spring cups for the 26918 springs on GEN1/2 SBC heads:
cc 4706-16
JEGS doesn't have them, ordered a set from CC, 2nd day air comes to $47.00, nothing is easy.
Eric
Old Sep 1, 2004 | 08:43 AM
silver & red CE
Cool!
I called CC about the cups. No kidding about the "TECH" line. I kept pushing for an answer on the spring cups, the tech rep finally went back to engineering and asked, there's a new part number for spring cups for the 26918 springs on GEN1/2 SBC heads:
cc 4706-16
Eric
Old Sep 1, 2004 | 12:27 PM
LT4BUD's Avatar
LT4BUD
I think the 7/16 issue was related to the rocker arms.....the "right" rocker arms weren't availiable in 7/16????
Have you picked out your rocker arms......again sorry I don't remember for sure, but some were too wide as I recall..
Like many other things you have to look at the whole package..
The people who did my heads didn't like my selections......they specifically do not like self aligning......they like guide plates.....but then they build race engines
Old Sep 1, 2004 | 02:27 PM
LT4POWR's Avatar
LT4POWR
nothing is easy.
or cheap...the mods always start out to be easy & cheap, but never end up that way
Old Sep 1, 2004 | 08:53 PM
silver & red CE
I'm going with the Comp Cam ProMagnum stainless steel rocker, they need guideplates...my engine's not a race engine by any means, but I do race it. I want to gt those LT4 springs out of there and go with some Ti retainers.
Thx for the help,
Eric
Old Sep 1, 2004 | 09:22 PM
No Go's Avatar
No Go
I run the 7/16 inch studs-thread right in. Also the CC Pro Magnum non selfaligning with guide plates.
Only catch with the guide plates is the LT1/4 head supposedly uses a special Chevy guideplate otherwise if you use a CC supplied one, the pushrods/rockers won't be 'perfect' ie slight crows foot angle to them. Now I have been running this combination for ~27,000 hard miles with no ill effects, but I will probably look at a different guide plate this winter.
You will like the 26918 springs...IM on the way.
To Need Help:Valve Train upgrade for LT4?
