Help: Harlan Shift Light Tach Setting
Old Aug 31, 2004 | 09:18 PM
silver & red CE's Avatar
silver & red CE
Default Help: Harlan Shift Light Tach Setting
I'm finally installing my Harlan shift light. Quick question: what cylinder setting should I use? I know the LT4 is a 8 cylinder, but the LS1 uses the 4 cyclinder setting. So should I use 4 or 8 cylinder setting?
Eric
Old Sep 1, 2004 | 12:06 AM
JasonL's Avatar
JasonL
8 cyl setting. LS1 has some odd-ball ignition setup.
Old Sep 1, 2004 | 07:27 AM
silver & red CE
Thanks for the help. Where did you tap into the tach signal?
Old Sep 1, 2004 | 10:48 PM
JasonL's Avatar
JasonL
I followed these instructions and used the tach wire after it comes through the firewall (above the cluth pedal)
http://www.grandsportregistry.com/te...ght/index.html
To Help: Harlan Shift Light Tach Setting
