hard brakes
Old Sep 3, 2004 | 08:08 PM
Loyal_87's Avatar
Loyal_87
Default hard brakes
My car has hard brakes, and I gotta get it inspected soon. The dealer wanted to charge me around $550. I was wondering what I'd have to do to fix it myself so I could save money.
Old Sep 3, 2004 | 08:32 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
You say "hard brakes". what do you mean? What year is your car?
Generally, "hard brakes" means a very hard pedal, lot's of effort, to get the car stopped!
If that's your problem, it is likely the vacuum booster behinfdthe master cylinder. Vacuum booster assists the brake pedal travel and force required to stop the car!
If that's your problem. you should be able to fix it for less than $200 plus your time
seeya
Old Sep 3, 2004 | 08:37 PM
Loyal_87's Avatar
Loyal_87
i got an 87, and it takes alot of force to push the pedal down, it stops fine once i get it pushed down though. if it's less than $200 i'll be real happy. thanx
Old Sep 3, 2004 | 09:04 PM
65coop's Avatar
65coop
St. Jude Donor '05
Look at the "check valve" on the brake booster or the hose going to it - if it has cracks.. that would be your problem.. less than a $20.00 fix!
Old Sep 3, 2004 | 09:06 PM
vader86's Avatar
vader86
Hard pedal=brake booster failure.
Just the part itself is probably over $200, if its not a broken vac line.
Old Sep 3, 2004 | 09:10 PM
Loyal_87's Avatar
Loyal_87
wow, that would be great if that's all it was. that means i'd have more money to make it faster. thanx!
Old Sep 3, 2004 | 09:39 PM
Loyal_87's Avatar
Loyal_87
now that i think about it, i'd hear a hissing sound whenever i stepped on the breaks, if that means anything
Old Sep 4, 2004 | 09:54 AM
alfonso gomez's Avatar
alfonso gomez
If you hear a hissing sound it's definitely a vacuum leak. Check the vacuum hose carefully. It's either that or the booster is shot.
To hard brakes
