Percy's Header Gaskets
Old Sep 4, 2004 | 05:16 PM
STL94LT1's Avatar
STL94LT1
Default Percy's Header Gaskets
Anyone using Percy's "Seal For Good" aluminum header gaskets?
Old Sep 4, 2004 | 06:36 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
I'm using them, and they work. Anything in particular you want to know?
Old Sep 4, 2004 | 06:41 PM
STL94LT1's Avatar
STL94LT1
Just wanting to know if they are worth the $$. I'm tired of replacing my Felpros.
Old Sep 4, 2004 | 06:47 PM
flyersfan1088
When I first took the Percys out of the package I started laughing. I suddenly understood how they could claim to be leak proof. Each gasket is actually 4 thinner gaskets pressed together, making one thick, soft gasket. Well worth it.
Old Sep 4, 2004 | 06:50 PM
STL94LT1's Avatar
STL94LT1
Thanks for the info, I'll order a set.
Old Sep 4, 2004 | 07:01 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Sounds like a good set-up. I've heard the copper ones are awfully good too. I'll soon be trying one or the other. Got a link for the Percys so I could check them out? Years ago I used to ride 2 stroke dirt bikes. My Yamaha mechanic told me I could use the copper head gaskets over and over. He said after a few times of R&Ring it you could just heat it up with a propane torch, let it cool down and still go on using it.
Old Sep 4, 2004 | 07:04 PM
STL94LT1's Avatar
STL94LT1
I tried a set of copper header gaskets when I was running shorty headers, and never could get even close to a tight seal.
Old Sep 4, 2004 | 07:18 PM
STL94LT1's Avatar
STL94LT1
Default Percy's Web Site
http://www.percyshp.com/seal4good.html
Old Sep 4, 2004 | 07:26 PM
Corvette Kid
Originally Posted by STL94LT1
Added to my favorites and THANKS!
Old Sep 4, 2004 | 08:34 PM
1MoorTym's Avatar
1MoorTym
I'm using their collector gaskets - good stuff !!
Old Sep 4, 2004 | 08:45 PM
JohnyH's Avatar
JohnyH
Added to my favorites too! Thanks!
To Percy's Header Gaskets
