Hubs: Visible Grease = bad?
Old Sep 4, 2004 | 08:56 PM
RocketSled's Avatar
RocketSled
Default Hubs: Visible Grease = bad?
I'm R&R (&R) ing the Sled's driveline, I burned up the transmission (purely operator error) and the phrase 'while I'm at it' got me into a LOT of trouble.
So, with the tranny rebuild, I'm fixing the broken speedo gear. Since I'm addressing THAT problem, I really oughta change the gear ratio (no sence getting in there twice), and if I'm doing the gears, I oughta swap in poly bushings...and while all the big parts are off getting the works, I oughta play with polishing the aluminum parts...
While disassembling the wheel assembly, I noticed greae escaping one of the hubs. There wasn't appreciable play in the hub before disassembly, but should I replace it 'while I'm in there'?
A hub swap is pretty trivial these days, but there's a high zoot motor in the picture, and I'd hate to have something fail nastily that could be prevented.
Oh, and here's the result of a little free time and a bench grinder:
with before and after here:
Curiously, it's the newer looking hub that's leaking.
Old Sep 4, 2004 | 10:24 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Grease from the hub is usually a good sign that the bearing is headed south. It's in the early stages, so you probably won't hear any noise or feel any play just yet.
Looks like you have everything out, so you might just as well go ahead and replece em!
seeya
Jack
Old Sep 4, 2004 | 10:44 PM
RocketSled's Avatar
RocketSled
yeah, that's about what I figured. :|
To Hubs: Visible Grease = bad?
