Adding NOS to my Supercharged setup
Old Sep 5, 2004 | 07:37 AM
Tomas's Avatar
Tomas
Default Adding NOS to my Supercharged setup
Hello Everyone
Im going to add a NOS EFI kit 05151 to my car.
Is my 30lbs injectors too small for supercharged and Nitrous?
What fuel pressure are you guys running with SC and Nos?
What is the partnumber for a NOS fuel safety switch?
Does NOS have a 58mm injector plate assembly for 58mm throttle body or is it just 52mm in the kit?
regards
Tomas
Engine size: 355
Block: L98
Compression ratio: 8.66:1
Heads: ported L98, 2.02-/ 1.60-inch valves
Cam: Comp
Rocker arms: Crane Gold, 1.6 ratio
Pistons: TRW Blower/Turbo
Rings: SpeedPro
Rods: Eagle 5,7”
Plenum & Runners: Lingenfelter Superrram
Throttle body: 58mm BBK
Fuel injectors: Accel, 30 lbs./hr.
Fuel pump: Walbro 340
FMU: ProCharger
Ignition: MSD 6AL, Accel 8,8 plug wires
Power adder: ProCharger 600B supercharger with intercooler
Boost: 12 psi.
BlowOff valve: ProCharger
Exhaust system: 1.75-inch-primary
Hooker ceramic coated headers, 2x3-inch pipes, Flowmaster mufflers
Transmission: Race TH700 with B&M Supercooler
Torque converter: B&M Holeshot 3000
Line-Loc: Hurst
Gauges: Auto Meter
Rear end ratio: 3,73
Wheels: Weld ProStar 15x6 front, 15x10 rear
Front tires: 195/65R15
Rear tires: 275/50R15 BFG DragRadial
Best ET/kmh: 11.72 at 187 (with very bad grip on first gear)
Best 60 ft: 1,64
