ZF-6 conversion parts
Old Sep 6, 2004 | 11:38 AM
redfast's Avatar
redfast
Default ZF-6 conversion parts
Just wondering were I can buy everything to go from a 4+3 in my 85' to a six speed. Did a search came up with nothing. Thanks
Old Sep 6, 2004 | 12:27 PM
LD85's Avatar
LD85
If I were to do it again, this is what I would do.
1. Stay with the Push type 1985 Clutch, CF Dual Friction & 85 Flywheel
2. Buy a McLeod Bolt on release bearing
3. Stay with the 85 Clutch Master
If you use the McLeod bearing, make sure that the ZF Bell housing is the 6.125 overall thick version
What I ended up with was a new Centerforce Single Mass Flywheel, McLeod Street Clutch Disc, Stock Pressure Plate, new 1996 ZF6 part # 12455189, ZF bellhousing and yoke, new 1992 starter to work with the ZF bell housing, Dakota Digital SGI-B speedo calibrator
Anyway, here is the infor from antoher forum member that did the swap.
I did the swap a few weeks ago so drop me a note if you need help. Also I have some tunnel cutting pics I can email you, I posted them but I think the server is down
http://hometown.aol.com/corvettez51r...age/index.html
Old Sep 6, 2004 | 02:44 PM
redfast's Avatar
redfast
Wow thats a great page. Im going to do it this winter. Sounds like it shouldn't be very dificult.
Were did you buy the new zf ?
Thanks, Mike
Old Sep 6, 2004 | 04:24 PM
LD85's Avatar
LD85
www.gmpartsdirect.com
$1800 + shipping of $205
Old Sep 6, 2004 | 05:46 PM
redfast's Avatar
redfast
Very nice I've been serching and the prices were around 4k for rebuilt ones. Thanks alot
Old Sep 6, 2004 | 06:43 PM
LD85's Avatar
LD85
Comes with Shifter, Back Up Switch,, VSS and oil!
Old Sep 6, 2004 | 08:20 PM
RichK's Avatar
RichK
Could you send me those tunnel pictures too?
Thanks in advance
RichK
To ZF-6 conversion parts
