Less Than Happy With ATI System
The first problem was the supercharger oil line installation items were the wrong size, I needed 1/8" pipe, the kit provided 1/4" pipe. When I called ATI I was told the parts had to be right as those were the only parts they had in stock. I went ahead and bought parts that would fit outside of ATI and proceeded. Next I tried to install the Fuel Management System (FMS) and the installation location shown in the manual was nothing like what I found on my car. I called ATI and after some lenghty conversation they agreed the picture and the instructions in their manual were incorrect. They did send me another bracket for the FMU but it would not work without me cutting and welding it and finding an alternate location for the FMU that would allow my hood to close.
Today I tried to connect the fuel lines running from the FMU to the factory lines and found that they are too short even though the ATI Tech had earlier told me that there was plenty of hose included even though I had to move it to a new location. My next option is to purchase 3/8"od fuel line and cut and fit it to make the connection.
As you can tell I am thoroughly frustrated with this kit. Tomorrow I plan on contacting ATI and letting them know what I think of their product. After all I have been through, I am worried about what the rest of the kit must be like to install.
Please don't purchase this kit without getting someone else's experience. I can only say that I would not do it again.
Take care.
90Indy
Take care.
90Indy
I can understand your anger. I have read a lot of your posts about your procharger experience.
I agree that the procharger ads say that this is a bolt on system, but that is not true.
I have finally got most of my issues sorted out and have plans to get the rest of them sorted out. I am really close now to getting things up and running correctly.
I have found out that supercharging is a very complex system (especially on a NA car). This is good that you guys are posting your results to let everybody know.
So far I am happy with my procharger system (for the most part), but it took me a year (after the system was installed) to get there. 389 RWHP (corrected) was my dyno reading after the install. The seat-of-the-pants feeling is that it is much faster than before as well.
The big thing to note is that, when you do put on a supercharger, the work is just beginning. It is not a bolt up and forget about system. I had the system installed by a shop (didn't run right after they installed it) and since then, I have had it off and on (modifying it as I went along) 3 times. People who are interested in supercharging need to know this.
I know that multiple people have said this. There are lots of issues with the procharger system (trust me I know). I think the biggest one is that people don't know what they are getting into (and the companies don't tell them either). I have learned a lot just from the corvette forum and my experiences with the supercharger.
I have come to the conclusion that the only way to do something right and know that it is done correctly is to do it yourself. Plus when something goes wrong, you will have better insight into how to fix it.
I highly reccomend a datalogger of some sort. It helped me out a lot.
Good luck guys. The learning curve is steep and a pain in the butt, but so far it has been worth it.
I have had offers from folks to buy the system, but I am just too lazy to go thru all the work. I wish I had spent the $$$$$$ on heads/cam.
I think the main problem is belt slip and I don't really feel like dumping another grand for a custom pulley setup.
At least I was able to talk my buddy out of making the same mistake.
And i coulnd't agree more with the head/cam/header work i wish i had gotten done instead of this $7600 nightmare... i could have done gears as well...
I know vortech makes better power and have better reputation then ATI. ATI really tries to sell you on their "intercooled technology" crap, when all those little intercoolers do is restrict airflow.
Sorry to hear about your bad experience.
That 389 is stock top and bottom end on a 6 speed manual. I am still trying to get the tuning just right. I haven't had a belt slip problem either. I have added colder plugs and an MSD 6al unit (spark was blowing out).
Remember dyno number can vary on a day to day basis. During some tuning I had I believe 360 RWHP to start with and then I got it up to 389 before stopping for the day.
I am going to get a wideband here soon to tune with tunercat. I already am using datamaster for logging.
When the system first was installed, I had an idle problem right off the bat. I spent 2 months troubleshooting that. When I thought I found the problem and fixed it, I had a dead spot in the throttle (so bad the car would stall).
Then I fixed that (took about 3 months of troubleshooting). I had to use a datalogger to find that (I found some problems I didn't know I had with the datalogger, too).
Then I went to drive the car and the clutch master cylinder failed and leaked all out. I replaced that and sure enough the car ran great.
Then, (just last week while I was pre-paying for gas), I come outside to see that my tire is flat with a huge gash in the sidewall. This is a brand new tire. I suspect foul play, but regardless, now my car is sitting in the garage on a spare tire.
It seems like the car is cursed, but I know it is just bad luck with the tire and each problem has been a learning experience.
I still have some things to work out, but all in all, I love my car. (I can't wait to get the wideband on it and start tuning).
It is not my daily driver and if I blow my engine with the supercharger, I will just have to rebuild and build up the engine. More money into it but it will be better each time. Plus the satifaction of doing it yourself is great.
Bruce
544rwhp Untune SC power
Prefer turbo system.
