87 ECM part numbers
Old Sep 8, 2004 | 09:38 AM
Don in Vermont's Avatar
Don in Vermont
Default 87 ECM part numbers
Hi,
Does anyone have the part number for a stock 87 ECM for a Vette with Auto Trans ?
Thanks,
Don
Old Sep 8, 2004 | 09:47 AM
SBNova's Avatar
SBNova
it should be 12277165, commonly referred to as a '165 ECM. The auto trans part doesnt matter- the trans calibration is in the memcal- which you will transfer over when you buy a new or reman. ECM.
Old Sep 8, 2004 | 10:38 AM
rick lambert's Avatar
rick lambert
And if you get a new ECM, also get the tool for r/r of the prom, watch where the notch is so you can install it correctly-if you don't get the tool (try a dealer) you may damage the prom or prom socket. BTW, I think you can get an ECM from Autozone for about $100.
To 87 ECM part numbers
