LTCC wiring help?
Old Sep 8, 2004 | 11:13 AM
99svrcpe's Avatar
99svrcpe
Default LTCC wiring help?
I'm finishing up the install on the conversion. however I do have a few questions on the wiring...my car is a 96 Lt4, no forced induction.
If I understand correctly the two pink wires on the harness will attach to the pink wire that fed the original coil and I believe the yellow wire will not be used with my setup, correct?. What wire on the ignition module will the white one be attached? What is the cause of the tach and ASR problems I remember reading about?
and finally how should I set the 4 position "mode" dip switch?
