engine timing
Old Sep 8, 2004 | 10:50 PM
toyvet1's Avatar
toyvet1
Default engine timing
I have my timing set at 6 degree advance on a L-89 TPI. Auto X-ray shows 40 degrees advance at 3800 rpm. Does the ecm electronicly advance the timing or is there something in the distributor that advances it. The metal cover over the star shaped piece under the rotor has some movement in it. Is that normal or should it be stable. I am running hot at highway speed and am wondering if I am acually getting the advance it needs....
Old Sep 8, 2004 | 11:13 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The ECM controls dynamic timing off the base timing value according to engine parameters and stored tables.
Use Monitor Mode and see how much timing advance you get during a WOT run through the 1-2 shift. I expect you will see around 36-38deg.
Old Sep 8, 2004 | 11:52 PM
comp's Avatar
comp
Old Sep 9, 2004 | 11:00 AM
conv90's Avatar
conv90
Your stock chip has a base timing set to 6 deg . It's a constant
You have the base timing (you can see it only with a timing light and the connector near the brake booster disconnected) set at 6 deg.
This is good because if the main spark table in your chip say that at a certain rpm level and at a certain load level the timing should be 40 deg, the ECM will add 34 deg.
If your base timing is 10 deg (your untouched chip has always 6 deg) and at the same rpm/load the chip table has 40 ) the ECM will ad always 34 deg ending a total time with 44 deg.
Your scan tool will report allways 40 deg
I'm pretty positive on all I said, but the last thing about what the scan tool will say...
If some experieced guru can chime in ...
-Beppe-
To engine timing
