'93 Vert shows SRC codes 21 & 31. Working through diagnostics I have a question about the shocks. The gears on top of both front shocks will turn (with some resistance) endlessly. They never come to a dead "stop". Does this mean they're broken, or is a slight difference in turning resistance all the actuator looks for to determine the "stop" position? I can't tell for sure from the diagnostic instructions in the GM manual which is supposed to be correct.
It makes the difference between buying an actuator or a shock. The price of either will undoubtedly be "shocking", so I don't want to buy the wrong one. Thanks for any help from experience,
From: Why are there squished peanut butter cups in my underware?
Originally Posted by swifty
The gears on top of both front shocks will turn (with some resistance) endlessly. They never come to a dead "stop". Does this mean they're broken?
Yes. The gear on the shock for a `93 will only have 90* range of movement. Most likely the "stop" at the bottom of the gear has broken off. That is why they will turn without stopping, and throw a service code to the CCM.
Thanks for the response. I was afraid that was going to be the case, since GM lists replacement shocks at just over $600 each. Any chance of repairing these if a guy is reasonable capable?
Anybody know of a forum sponsor / member who offers a discount worth chasing replacement adjustables - or a source for servicable used units?
You can buy them new from Mid America designs for under $200 apiece. If the gear is broken, bilstein will charge $150 plus shipping per shock to rebuild, so you may as well just buy new.
I believe a 91 has 90 deg range of motion. 92 and up has 160 deg.
